Ideally want the solar to power the house demand and then excess to charge battery when electricity is peak (05:30-23:30)
Before electricity goes cheap at 23:30 until 0530 I want to still use PV and batteries to supply demand but want max discharge to grid -
Then plan to charge up batteries when it goes cheapstrong text
Hey,
I do similar. However I only drain my AIO once a week. Normally Sunday.
Timed charge set from 23.30 till 05.30 everyday. With eco mode on and that should do what you need on that front. As soon as solar up, will top up batteries power the house and export at 15p.
Unfortunately with regards to the export unless you use some kind of automation. There’s no 100% way to not end up pulling from grid before cheap window or maxing out battery discharge.
I normally drain my battery Sunday evening down to about 10% through the app manually by 10pm.
Couple hours at peak discharge. 6kwh. I would do slower but my giv EV charger keeps overriding the settings for some reason. Separate issue.
Only reason I do the discharge manually as it can vary so much depending on usage that day and the weather.
