I use this and it basically looks at lots of inputs ( weather / iBoost / EV Charger / Tarriffs ( get’s info from Octopus energy ) and then calculates the best way to optimize your system.
There are loads of things you can tweak as well to make it for just for you - and it is being developed all the time… I have requested a “Storm” feature so that if a storm is coming that it charges to 100% and doesn’t discharge until the storm has past in case of a power cut.
I even created simple automation so that when it detects the “Free Sessions” from Octopus that it turns my iBOOST+ on ( as well as charge the batteries ).
Loads of videos on how to set it up - but here is a sample of how is automatically scheduled my system for today.
Hi Briggo. Not sure what you are setting to zero. It needs to be that the “charge power” is 0, and the “discharge power” is (in my case) 2600W. I do this from Home Assistant but in the app battery:settings:battery options, then adjust the sliders to the above. The inverter then cannot charge but can discharge as normal.
Yes, when I tested it it’s set to 0% under the ‘charge to %’ in the timed charge setting and discharge is at full rate of 6kw (all in one), eco mode on.
As soon as I set that 0%, it stops the battery from discharging to cover house load and utilises grid only.
I used to charge the battery up fully overnight … but in the summer that is the WRONG strategy.
I’m on the Octopus plus tarrif.
My new strategy is to make sure that the battery is 100% full by 4pm (peak export tariff). If I fill up too much at night and fill up before 4pm what that means is I have spent 16p on a unit overnight rather than leaving the battery less than full. Then during the day (in the summer) I have to sell the spare units that my battery cant store at only 10p. By overfilling the battery I am making a loss.
Have a look here for a detailed explanation.
The first part of the video explains this. The video goes on to explain a technical solution to optimise battery charge and gets geeky,
