Morning,
Have had a look through quite a number of previous posts, and although many mention it, can’t find one that actually answers this specifically -
System is advertised as having a full 13.5kWh discharge available, but in practice only 12.96kWh is available for discharge as the system reserves 4%.
I could understand this if it was only a 13.5kWh battery, but as I understand it from what’s reported in HomeAssistant, it’s actually a 16.5kWh system, which allows for a ~19% margin to avoid extreme states of charge either end damaging the cells. Much like the 9.5kWh system that is advertised as having 100% discharge - it’s 100% discharge of the available capacity, the 9.5 system is also bigger, just the full capacity is hidden from the user.
So does anyone know why the additional 4% export restriction is applied?
