Battery failing to charge
Just when power prices go negative, my battery stops charging. (GE all in one + gateway, no solar PV) I had a notification last night of the clock reset. I have a hard link to the router, so no wi-fi issues. I’m not that tech savvy, any pointers would be appreciated.
check all the breakers in your AIO are on, nothing tripped
then do a ‘reset to defaults’ in the portal should reset your inverter and get it going again. You will need to re-program any charge slots
Thanks Geoffrey. After a stuttering start (claiming to be offline) it is now charging. I appreciate your help.
