Battery Firmware Update
Quick question Questions…
Not had to complete a Battery or Inverter update but noticed the battery firmware updare button appeared.
Generally firmware updates are needed so needs to be done.
Getting the best time
What are the gotchas here?
Battery calibration? will the battery discarge to 0% and charge?
Assume the inverter will be offline so running from grid
Any Known issues
Possiblity of failure
I would assume that the best time to do this is when the battery is almost empty and able to import from the grid off peak?
Thanks In advance.
inverter Firmware Version
D0.309-A0.309
Last Update Time
2024-08-16 10:06:20
Battery Firmware Version
3017
Click the button below to upgrade your system software
This process will take 5 - 30 minutes, depending on which software your system already has
Please ensure that the inverter has both a grid and internet connection during this time
Once the process has started, you may close this page and the update will continue in the background
The wifi dongle will be updated, the inverter will also reboot and may take up to 10 minutes to reconnect
Dongle firmware will be upgraded to 206
Yes, your assumptions are spot on. Though a calibration is not always required, for my AC3, if using the portal I would do mine some time after 11pm. It takes a few minutes to apply the upgrade and discharge (time depends on state of charge when you start), so by the time it starts charging it should be 11:30 and off-peak prices (I’m on IOG). BTW it’s worth monitoring that it applies the firmware OK - sometimes you need more than one attempt.
Thank you for the advice would be useful if there were release notes stating what’s fixed and what will happens or not happening during the upgrade.
Hyper link in the notice message would be perfect…
I am waiting for an opportunity to sit with the upgrade.
I have a midnight to 0700 cheap rate window, I will kick off at just after midnight complete the upgrade then a calibration can start if needed in that window.
If the battery is offline during the upgrade which I suspect is the case its better to complete during the cheap rate window so incurring no additional costs.
Link to what is actually fixed is here :
Perfect Thank You.
