Battery issues and no response from support
I have a GivEnergy HY3.6 Inverter with a 5.22 kWh Battery, and after working really well for nearly 2 years, the battery now longer charges from the solar PV. I have tried restarting the battery (the green switch has not tripped), updating the firmware, and force-feeding it from the grid, but it only just slowly discharges (6-8W) back to the grid. In the good old days, you could call GivEnergy and sort out the problem, but now having sent various messages earlier this week (via email and their messaging system), there has not even been a confirmation that they have received anything.
They used to be so good - anyone any idea how the best way to get in contact with them to sort out issues - or do you just have to hope that someone eventually responds?
I have always found that emailing them has been a quick process, but if not then the support number - 01377252874 should work
I bet you might need a Battery calibration
Thanks - I’ll give them another try. The past few times I’ve tried it just sent me to the contact form on their site, but maybe I’ll keep persevering as that is the way I used to get through.
I think their phone line shut in November, and it’s been hard to get hold of anyone since :(
I did get through on the phone - after waiting for almost 90 minutes - and the battery is now charging from the PVs, but I need to get back to them as the app live readings are completely inaccurate.
Best way Is to go to givenergy users on Facebook and place your query there, you will be very pleased you did.
Interesting. Thanks, I’ll give it a go. Beats over one hour holding on the phone!
Hi, were you able to obtain support in the end?
I have been in the same position for a few months now, the support is really poor.
A software update has essentially bricked by battery but you cannot get through on the phone, only use chat, but they are not resolving and there is zero escalation process.
My next step is small claims court at the minute as I have no other option.
Antony
Did you get your problem resolved? I also had a FW update brick my batteries. Hard work to contact anybody but persistence eventually paid off and I got an acknowledgement that the invertor may need to be replaced. (I even contacted the MD on LinkedIn) Still waiting for Installer to confirm when that will happen and nobody is giving me answers.
Did you get this resolved?
It took a long time but eventually GivEnergy paid my installer to replace the invertor and it has been working ever since. Whatsapp was the best way to contact them. Although I also contacted them on LinkedIn.
I’ve been waiting since 3 January for a response from GivEnergy after reporting my battery suddenly stopping working. I’ve emailed 6 times and have had no response from a human being, except two automated responses assigning two different ticket numbers. I have phoned the support line and spoken to an AI robot, who assured me that ‘she’ understood my concern, had marked it as urgent as I had requested, and someone would contact me very soon. Nobody has.
I have provided the diagnostic information from the system (which confirms there is an issue with my battery and GivEnergy can help so I should contact them). I have asked that they send an “Activate battery” command to my battery, which sounds a very easy thing for someone to do. Still no response.
I have tried recalibrating the battery - doesn’t work.
How do you contact them on Whatsapp? Thanks for any advice!
We have the same problem, I am still waiting for answers
