Having set our GivEnergy battery reserve at 21% the battery dropped to 8%. This has happened on a number of occasions. Could this be due to temperature which was below freezing this morning?
Is the software ignoring our settings for another reason?
My battery frequently drops below the setting I enter. I only recharge from solar panels so this time of the year its quite often. Eventually it drops so low it recharges from the grid. I have given up trying to find out why it happens. If you get an answer please let me know Many thanks.
You don’t say how you set the reserve (portal/app/GivTCP), but I’ve found sometimes that it doesn’t take and it’s worth reading it after setting to verify it’s been really set.
I set in the app. Quite often I quit the app re-open and check. It always seems to save correctly and we do this often so we can charge the battery overnight thanks to the Octopus Go tariff.
I believe it has been recognized as a problem - I certainly have made GE aware of the occurrences both directly and via installer. My understanding is that there will shortly be a software update for Giv Hybrid gen 1
