Is there a wifi enabled CH controller which is compatible with Givenergy hub (and uses the same backplate as the honeywell one)?
I’d like to be able to use my Givenergy battery for heating, using IR radiators, but I’m still going to need to burn a bit of oil from time to time, so need to be able to read the thermostats and program the boiler
