1st post after having AIO unit installed 3 weeks ago. This doesn’t always happen, but yesterday was the 3rd or 4th time i’ve seen this. From the graph below you can see battery start to charge (dark blue below the line) and the battery temp start to rise from about 8am.
So i assume the inverter is actually charging the battery) However, the battery percent doesn’t change from 77% for 2.5 hours, not until around 10.30, then zooms up to nearly fully charged in 30 minutes.
I suspect a stats issue than a fault, but has anyone else seen anything like this.?
