Just a heads up, it is not possible to select an AC3 with two 8.2 batteries, once you select one 8.2 the option is removed, even typing in the search bar does not allow you to select 2.
Same for me. I have 2 batteries also, but I can only select oneâŚNot sure it matters thoughâŚ
If they are looking for a certain subset to test beta firmware it might.
thought worth pointing out as it is wrong wether important or not. ![]()
Same here, but not sure where that information actually goes.
Thanks, we have added â2x GivEnergy Giv-Batâ options as an experiment for you to better represent your setups. Try it!
Yes that works. took a while to navigate to it. its in the âprofileâ section if you are logged in.
This appears to be the only way i can post now. (reply to myself) if i try to create a topic in any other category i get "youâre not allowed to create a post " as a beta tester i wanted to impart some info?
have i lost some permissions somehow?
Hi Positor1, try log out and log back in to see if it solves the issue. If it doesnât, you can post it in General and I should be able to help you move it into the proper category afterwardsđ
