My Givenergy 5.2kw battery and inverter have been installed in my rear garage 30 metres away from my consumer box. The initial CT clamp was wired in using some exiting telephone cables I already had installed from the house to the rear garage. However this cable is now malfunctioning.
Would I would like to consider is replacing 30+Metres of cable with a RS485 to Ethernet converter making the system look like:
Battery (garage) → RS485 Converter → Ethernet Hub → RS485 Converter → CT Clamp (house)
I’ve read on various forums that this is possible but wanted to know if anyone had experience with this setup using a Givenergy battery? Or indeed a viable alternative?
