Hmm I read with some interest the responses , some factual and some well we won’t go there.
is it a single point of failure yes and no, yes if the EMS stops working because it has developed a fault then yes, but you can recover this by utilising inverter 1 turn on eco mode and set meters to 1, and set up your normal charge and discharge routines until you have replaced the EMS. you might have to restart the Inverter or get support to do a grid code reset to remove the alarm
So how many EMS units have completely failed 1 and that was at install and I suspect that was because the installer tried to change the MSN File and removed it but couldn’t put it back on.
most issues are inverter or battery related and you would have suffered those EMS or no EMS, the EMS continued to work as long as it could see a grid meter and ignored the faulty Inverter, Predbat and balancing software can not operate as quickly as direct Modbus connectivity, I don’t care who you are it’s a fact I know I built it tested it and do this sort of thing day in and day out.
The EMS makes decisions every 300ms and changes every 1200ms you can not do that with API/ or Modbus over TCP, people get a little confused because the out put you see is every minute , that’s a snapshot, go look at the meter data, like any other piece of equipment you need to set it up correctly.
Ask valiant, we ran a house project with them and the overall cost to run the house with two EV’s and a heat pump was £-135 for the year, valiant published a white paper on it, two ac3 inverter and two 9.5kwh batteries
feel free to not use an EMS but two inverters on same cct is not supported, unless they either go via an EMS or are designed to work in Parallel, the general cost in energy for running the EMS is approx. 800w for two inverters over a period of 24hrs, so it is more efficient that just running the inverter without the EMS again that’s been measured. this is due to ramp up and ramp down speeds of the EMS.
biggest problems I see is installation getting some to understand that in Modbus terms efficient communication requires good connectivity so no wago connections on the cat5/6 cable, two pairs doesn’t work better that a single twisted pair, use the best spec cable for the Meter and inverter communications .
so you can now go away and make an informed decision.
