Noticing on octopus mini device and other sources of data that there are bleeds of power to grid throughout the day mostly in single digits sometimes 100s of watts…not a lot.
Lots of zero import too!
…feel I’m being too fussy about the power seepage…? or is there a tweak to squeeze out every drop…!?
Sorry for the necro. I see this too. Even with very little load, or as I have timed discharge on, i see that the battery is constantly outputting about 100w of power whether it’s needed or not. This happens until the battery limit that I’ve set of 10%, where it will stop that ‘bleed’ discharge.
I assume that this is somehow linked to the whole home backup? Or perhaps it is using the power draw and voltage drop on that 100w of output to decide if it needs to ramp up power output.
