So like many Gen1 equipment owners, I was initially excited to hear about the EMS being developed and tested by select customers.
I’d also seen a YT video by ‘James and Kate’, who visited GE last year. They mentioned the possibility of some kind of buyback scheme, but I’ve only ever seen it mentioned on their channel.
Now we have GE selling inverters at 50% off, when purchased with a low voltage battery.
Starting to think GE just want to purge all their older, less capable kit and have no incentive to actually design and produce an EMS?
Why would they, when customers with gen 1 Inverter and batteries would be ‘incentivized’ to move to the likes of the AIO.
Anybody have ANY news on the EMS, other than the info shared by George Rawding in the live Q&A back in August 2023?
Hi Stuart
We have a Beta EMS on trial and can say that it has been faultless in the 10 months that we have had it.
We have 2X Gen 1 AC3 Inverters and 2 X 9.5 batteries – cross charging and SOC imbalance etc has vanished since EMS install.
Don’t know when it is likely to be realised for sale, can only imagine that GE are still gathering data from the various locations and different setups that they currently have on trial.
If you really need one, try asking GE directly?
Good luck
Mark
This is great news as I have exactly the same arrangement as you. I’m still on 3015 and avoiding any updates until I get the ‘all clear’ on a newer version. As you did, I find the cross-charging and imbalances a real nuisance and have to constantly micromanage them.
I’m on Octopus Cosy and using the three cheap slots. I use the Octopus R&D Labs portal to set up the slots as the Smart Card Beta seems very unreliable for me so far. What do you use?
Not currently running HA, started using it some time ago but not being very techy had a few glitches found it too time consuming for me to sort so it’s temporary abandoned for me!!
Not sure if you can run ‘Predbat’ with the EMS anyway? Are you?
Thanks for your encouragement.
I was using GivTcp with HA until the EMS was installed. It’s the EMS that can’t handle GivTcp or visa versa.
I think also Prebat isn’t an option currently with the EMS.
Must admit too that the EMS has been so good I’m very reluctant to upset it!
Thanks again
Mark
I have a similar system - 2 AC3’s with a 9.5 and two 5.2’s. Real problems with cross charging etc, escallated to GE who suggested HA with the balancing software as the EMS wasn’t ready and the HA worked well.
GE then offered me a beta EMS unit and it has been in place since spring 2024 and has been working really well without any issues.
I was told to remove the HA as it can conflict with the EMS - I suppose they are both trying to do the same/similar thing. I think there might have been something mentioned about modbus getting overloaded.
No idea when GE might offer the EMS as a production release for wider use.
As stated, I don’t have multiple inverters YET, but I’d rather wait for a official EMS product, rather than tinkering with Home Assistant.
A tad frightened about buying additional kit, and then having to devote time to getting it working. Money isn’t particularity the biggest concern, but time is unfortunately.
I could ‘simply’ rip out what I have and go for an AIO, but it seems that I could achieve the nearly the same (or more) with an EMS and additional Inverters and battery, and have some redundancy as opposed to a single point of failure to boot.
I did email tech support, but wasn’t hopefully in getting an answer, especially with the nature of my current setup.
I think realistically the roll out of the mainstream EMS is taking far too long, there are a lot of unhappy people that have been in contact with me asking about progress of the EMS (I’ve been very lucky to have one). I think people feel that GE are dragging their heels with it because of the commercial viability. But when so many were promised the EMS back in 2022, it’s getting a bit late now. I’d love to actually hear what the hold up is and the reasons for the slowness to push it through from the top!
I’m ‘fortunate’ in that I’d not invested in multiple inverters, but if I feel forced to rip out and start from scratch, then I’d certainly look at other options from alternative manufacturers.
I’m 26 months into ownership, and between the SoC gremlins and other issues, it wouldn’t take a great deal for me to become a customer elsewhere…
“The EMS first iteration which is for AC coupleds specifically is due to be released in Q1 of 2025 if all goes to plan. The development of the EMS for Hybrids is still on going”
So I guess for hybrid users it’s a case of not holding your breath I guess lol
Could anyone with experience of the EMS let me know:
Whether the EMS presents a single point of connection for things like programming charging slots, such that connection is made to it, rather than individual inverters?
Would the existing grid meter and solar CT clamp, wired to my single inverter, be rerouted to the EMS without the need for additional
metering/clamps?
Is my GIV-AC3.0 inverter OK for connection to an EMS with firmware D0.212-A0.212 installed?
If the EMS is connected to a wired LAN connection is there no need for the inverters to connect to WiFi?
Is GivTCP able to interact with the EMS now and if not can it interact with the individual inverters after an EMS has been installed?
Can the emergency power outputs be used on the inverters when connected to an EMS?
I did post a couple of the above points in the inverter area but this seems to be a more appropriate place.
Hi I have posted the same question as I was in The NEC last week and was told that the EMS was ready for my 2 Hybrid inverters with batteries
However I still only see ones fore sale stating AC coupled inverters
Have you heard any more since
Regards Dean
Correct, all communications goes to the EMS and it talks to the individual inverters
There is a specific (new) firmware for an inverter connected to the EMS. In effect it rips the brains out of the inverter as part of connecting it to the EMS
GivTCP can interact with the EMS, there has been a lot of development of this. I don’t believe it is 100% perfect yet, but it is definitely getting there. Once you connect the inverter to the EMS you can’t communicate with the inverter individually, it is basically a brain dead inverter that only talks to the EMS
I would imagine that the answer to 5 is that since all comms goes via the EMS and the inverters are wired to the EMS directly, the inverters don’t need a wifi connection
