EV charger screw position dimensions
Can the EV charger be post mounted? If so, what are the dimensions of the bracket and screw positions and the screw position dimensions of the EV charger unit .
Here’s the installation manual https://givenergy.co.uk/wp-content/uploads/UK-Installation-Manual-EV-Charger.pdf
The installation pictures all show it being fitted to a wall. I’d suggest your installer contact GivEnergy support to ask about post mounting
Thanks. Yes looked at the installation instructions already and rather unhelpfully there are no dimensions. I don’t see any reason why it couldn’t be post mounted. My plan is to either use the MacLean post which has multiple mounting holes/slots or a large woodon post concreted into the ground.
