EV charger using battery stored electricity
Recently had an AIO, GW and Fox ESS PV inverter installed along with the Giv EV charger.
The settings on the app are in hybrid inverter mode and prevent battery from discharge, however whenever trying to do so it’ll draw from the battery.
The EV charger is wired directly into the GW with no additional comms meter.
Similarly if I put it in solar mode, it’ll again draw from the battery - any solar over 1.4kw + battery kw rate to increase it to 7kw output.
I’m assuming the EV charger doesn’t need to have a comms meter on it given it’s wired into the GW? Is this a software issue?
Any help would be appreciated.
Having spent some time looking at this problem (House battery discharging to EV) and reading reports from other people, I’ve reached the conclusion there is no easy solution. I don’t have an AIO but do have a Gen3 Inverter, Gen2 Battery, GE EV Charger and 16 solar panels. As far as I can work out, export to the grid happens when there is surplus PV energy available and all systems try to only export as a last resort. So, if the EVC is calling for power and there is insufficient power coming from the PV panels, the system will draw extra from the grid to make up for the shortfall. But if your battery Is set to discharge (either because Eco mode is on or you are using a timed or automatic export schedule to upload to grid at peak rates) then that shortfall will be met by your battery instead. The best I’ve been able to achieve is to use my Home Assistant setup to switch off battery export if it detects that the car is charging at the same time the battery starts to export. As an aside, with my setup I’ve also found that the EVC operates more reliably when configured as a standalone module, I.e. not under control of the GE Inverter. I realise this seems counter intuitive but until I charged it to standalone I couldn’t even get it to charge the car at more than 6 amps / 1.4kW. This i think certainly is a firmware issue and there has been talk of an EVC firmware update coming at some point. Hope this info helps.
The EV charger is sold on the basis that it can do exactly what’s being asked, you shouldn’t have to find workarounds.
It’s sold on the basis it can do what the Zappi does (charge using only excess solar) but better and not discharge batteries when hooked up into a GE ecosystem. It doesn’t do either.
It’s getting increasingly frustrating with GE that the products don’t stand up to what they claim or at least respond in a reasonable time frame to assist installers/customers with how to ensure it does what it’s supposed to do.
This isn’t my first problem with a system that’s been running about a month.
Have the EV settings been checked? My AIO,GW, Fox inverter and GivEV charger do not pull from the battery when charging the EV, it’s set to Solar or Grid. If your battery is being used to charge the EV a setting must be wrong? Remember the house load figure on the app includes the EV, battery might be taking up the house load element (not as far as I can see but…..) but ours does not discharge to the EV as that is what it is set to not do.
Hey,
I have had some quirky behaviour around getting the EV charger to work as desired particularly when octopus is giving cheap rates in day for me to top up my EV/battery.
If charging my EV in the day it will use solar and then any shortful pull from my AIO.
I normally just avoid it and charge my EV in the cheap rate overnight when my AIO is charging to avoid all this.
However a workaround seems to be to leave “prevent Battery charging to EV” off until after charging begins turn it on. My AIO then drops to around 400-500w.
Configuration: Inverter control, toggle “prevent battery charging to EV”
Ideally there needs to be a big firmware update on the EV charger. Definitely doesn’t seem to work well with other giv kit particularly well.
Iain
It could be a wiring issue, there are some drawings on the forum that show how to wire EVC via Henley blocks so the inverter doesn’t seem the charger
I was suffering the battery drain when my EVC was plugged in. My EVC is an Ohme. The installers came out and usung(they said) a CT clamp now my battery is invisible to the EVC and charging does not even appear in the GE app.
