Current install
3.6 SolarRiver inverter + 3kW Array (receipt of FiT)
Planned install
Retain existing separate PV array + inverter
3x5.6 Batteries mounted in 12mm cement boards in garage
Hybrid 5kW (Gen3) OR AC Coupled
Main consumer unit in house.
Planned garage consumer unit…
Proteus 6 way consumer unit
63A RCD - Linked to connector block in cabinet
16A RCBO Bi-Directional B Curve - PV Inverter
32A RCBO Bi-Directional C Curve - Battery Inverter
32A RCBO - Sockets
6A RCBO - Lights (in+out)
GivEnergy GEM120CT
Future plans
- Heat pump
- Solar diverter
- Home server
Please note that the existing PV + battery inverters will be separate (to maintain Feed In Tariff compliance)
I’ve made a G99 application to the DNO for the 5kW Inverter of the above setup and am awaiting approval.
My questions are:
Is the garage consumer unit okay?
Which bits would you ask a GivEnergy installer to do and what could a non-solar electrician do?
What bits can I do myself?
On the “bits myself” (whilst I wait for DNO approval). I’m thinking
- Install the sockets + lights
- Mount the batteries on cement boards
- Mount the inverter on cement boards (noting the spacing guides etc)
- Mount the ancillary items (ducting / breakers etc)
It’s really important to say that the garage consumer unit is not connected, and I won’t be actioning this myself (I’m not an electrician / installer). However I am confident to do basic electrical DIY + follow installation guides etc.
