I’m looking at getting a PV system installed with a Giv-HY5.0 V3 and a Giv-Bat5.2 battery, is anyone here a radio amateur using the same equipment? I’m concerned about interference on the HF bands 80M to 10M. I’ve seen some horror stories regarding PV setup and interference on the bands and thought I would ask here. I know there are many hams using PV on their houses without issues but with an expensive shack setup the last thing I want to do is add interference by installing the wrong inverter.
I have Hy3.6 v3 and 9.5 batt. installed last July. I asked installer if they earth the PV frames and they said no. I have 15 + 17m dipole only a few m away from panels, other antennas about 15m away. I have not noticed any interference on HF or 2m. I mainly use digital modes though. I have a wide band SDR Rx only and again not noticed any interference when tuning around 50kHz - 1GHz.
Thank you for the replay, it’s good to know the system is working and no QRM.
Thanks again
Dale
EI7HDB
