John2
June 18, 2026, 9:32am
1
I recently changed wifi details and had an issue re-connecting my EV Charger as the label on the side of the charger was faded.
After trying a few times, I removed the charger from my app to try starting from initial setup again but now I can’t get it back on at all.
My EV Charger details,
GIV-EV-7.2
S/N C12405G118
EVSE-06838847
For reconnecting can anyone confirm the correct needed,
Serial
Username
Password
@TheDragon
John2:
EVSE-06838847
Try this.
A strong Wifi signal is required at the site of the EV charger at all times during installation and also to the phone doing the installation.
Turn the EV charger mains supply off and then on again. (Listen for the beep)
Launch the Givenergy App that has already got a valid SSO login created and works correctly
From the App menu select EV Charger
Select Start Setup
Scan the QR Code Above
Turn Off DATA on the mobile phone being used for the install
Enter the home SSID for a 2.4ghz WiFi network that is strongest at the EV charger
Enter the password to gain access to the Wifi connection then click connect
Choose EVC installed with internet connectivity and mains supply only (Givenergy’s current recommendation)
Enter The Max size of the fuse in the Meter Cupboard usually either 80amp or 100amps Check first.
Complete the install it can take a few minutes of the app with a rotating symbol be patient.
A notification message will appear on the GE App phone and the portal saying the EV charger is installed.
John2
June 23, 2026, 7:05pm
4
Thanks, I will try that.
Do you happen to know my or where I can find? As backup option.
Serial
Username
Password
scan the QR code with your phone and read the text.
ChunB
June 26, 2026, 10:28am
6
Hi, I’m in a similar situation. My home wifi has changed some I’m tryingto update the EV charger; the QR code on the charger has worn away so I’m trying to setup manually but so far none of the passwords I’ve tried are workingand I’m unable to connect to the EV Hotspot.
My EV charger details are:
S/N on unit: CI2405G005
Serial Number from app: 11288853546701
Network: EVSE-53546701
Passwords I’ve tried are:
12345678
45350425
53546701
87654321
012345678
If anyone is able to confirm exactly which Serial number / network / password I should use, that would be much appreciated. Is there a way to factory reset the unit so that the default password (12345678) can work?
