Hi all, hopefully an easy question - in the mobile app, my battery will read 100% and then my system will begin exporting all excess to the grid, but if I check HA/GivTCP, the charge will read 98% and trickle charging (20-40W).
Is there a way of syncing the percentages? Do I need to run a calibration, or is this just a quirk of GivTCP?
How do you access the battery percentage via the Inverter with GivTCP? Or can’t you? I’ve only recently set up HA due to the whole Administration thing
