When exporting to the grid (timed export), the battery will show 6kW discharge but this is being split between the grid and the home (ca 1.7kW to the grid and 4.3kW to the home). This is clearly wrong:
Before the grid export, the home is consuming around 400w. As soon as the export starts, the home shows 4.7kW
The total grid Givenergy export today number will show something like 5kWh but Octopus shows around 20kWh
The same also happens when solar is being generated. 7kW being generated by solar but this shows as huge amounts going to the home while around 26% is going to the grid, but there are no significant loads in the house (no emersion heater, dish washer, washing machine etc) and again, the grid meter is showing more grid export than the AIO/Gateway.
Originally, the export numbers matched the grid meter numbers. This changed after having solar installed and maybe after a site visit to try to fix an over voltage issue on the PV inverter.
A recommission was executed on the Givenergy devices and I also notice a “CT Direction” setting changed to “positive”
Thank you so much for the advise. I have just been talking to the installer and yes, it was in the incorrect position. After flipping the switch, the energy is now being reported out to grid correctly.
I also have impossible app figures since the update to 13, see post ‘update bug’… My Bypass breaker is off… No idea what the sytem is actually doing but as I can’t be sending 17kW to the grid and using zero in the house… AIO/Gateway resets and app delete reinstall doesn’t fix it…
