Hi, hoping for some help please in understanding what is involved in having more than 1 AIO on a single phase domestic setup?
Would both AIO’s be able to charge independently, but still visible in the same account? Is anything needed to avoid them charging each other? etc
Is the Gateway required? (I feel like I may have overlooked something but doesn’t feel like it offers much if not installed between the main consumer unit and the incoming DNO supply + connected to a separate local earth. Would be a lot of extra wiring in my case as meter & existing CU one side of the house and garage the other…)
For context I haven’t got an existing solar installation, I would be looking at getting this as part of a complete package. Mainly attracted to the high AC charge rate (for the capacity size)
Unless something has changed in the last month, only a single AIO can be installed at the moment, it is a future plan for additional units. AIO can only be purchased with a gateway at present.
This is me expressing an interest in testing a second aio.
I will be getting a heat pump soon.
Def interested in extending my current aio.
13.5kWh seems a lot to most. Working from home as a dev, “normal” base load can drain it within the day. Adding an ashp which can draw up to 1.5kWh when cold, would drain it well before peak even with some winter sun
