Inverter charging times being changed by GivEnergy-Octopus S. (GivEnergy)
If I change the AC charge times, they are changed by GivEnergy-Octopus S. (GivEnergy). The end charge time is 04:30, which does not reflect the current Octopus Go low-rate window.
How do I ensure my values are not overwritten?
Log entries
18/12/2024 11:28 You AC Charge 1 End Time Written Successfully 04:29 05:29 05:29 App - Inverter Settings - Timed Charge
19/12/2024 00:07 GivEnergy-Octopus S. (GivEnergy) AC Charge 1 Start Time Written Successfully 03:30 00:30 00:30 API - Inverter Settings
Did you used to be on Intelligent Flux?
If so, kill the tokens in the portal (under account settings). Or remove the device via the octopus app.
If you were using smart tariffs, check the giv app or the giv portal for tariff cards and click the stop automation button.
Likewise if you were using wonderwatt or other external tools, stop those too.
I have never (to my knowledge) used Intelligent Flux . I had recently signed up to GivBack, so have disabled that to see what happens.
I have just exported my logs as I was also part of the Givback and also the Octopus Shared Saving session - but I see nothing in the logs I have just downloaded and put into Excel
Even the ones that are NOT me are from ages ago…
It’ll be givback. When you sign up to that, you hand over control of the inverter to them.
Finally found the Octopus token and removed it. All OK now.
Thanks for the advice
hi Im having similar problems, whereabouts did you find the token on the portal in the end please?
Not entirely sure, as I may have tried more than one solution. I think it was on the GivBack menu page.
