Hi, I’m considering getting a GivEnergy system but I’m wondering if the inverter/battery requires an internet connection?
I know it would need one to query say the Octopus agile API to determine when to charge/discharge etc. but does it need a connection for anything else?
I saw firmware updates and battery calibration mentioned somewhere so I guess automatic updates would require it, but could I use a usb stick to update firmware instead? Can I calibrate the battery manually?
That’s just what I was looking for, thanks! In case anyone else needs it:
If the system is offline for more than 10% of time from the date of installation, the warranty may revert to a 12-month standard warranty from the date of commission.
Honestly, this is why I asked. I saw people reporting that givenergy/installers have remote access to start a battery calibration at any time (including when energy is expensive). Bit worrying they have a backdoor in to the network by default too. I’d definitely put the battery on an isolated IP or block access to other devices in the firewall
I have suggested to GivEnergy that they schedule battery recalibration for the off peak periods but I’ve not had an answer.
It should be a no-brainer but…
