Latest Dongle Firmware Files
Please could someone explain where the latest change-logs and files are for a GIV-HY-8.0-G3-HV inverter, or more specifically the HF21 Wifi module?
The inverter is auto-updating and currently at D0.005-A0.005-A1030.005 which it did on 12-Feb-2026. However, looking on the GE support page for GEN3 HV, the last log is for version SG050505 on 18-Mar-2025! How are these version numbers related, and why are there no recent change logs?
Also, the cloud reports my Wifi Dongle is at version 1203, whereas logging into the inverters local webpage, that reports the interface firmware is version V1.00.03. However, looking on the GE support page, the HF21 Dongle Chipset, which I believe the G3 with internal Wifi uses, has versions Chipset-v27 and Boot-1.14. Again, how are these versions related?
As there doesn’t seem to be any GE support, I’m trying to eradicate the problem with sporadic network glitches and hangs myself. I’m connected by ETH rather than Wifi.
Hi yah,
I don’t have the same inverter as you but here is a link to the latest files available if your not in a Beta Program.
I am trying to get the firmware to upgrade my inverter to 1203 by flashing the dongle but these links you provide are dead. Does anyone know where to find it?
Is this of any use
