Does anyone else think the new widget needs an option to not do any automations at all. I run my charging strategy from a smart system that is built on Home Assistant that accommodates, the heatloss of the house and heatpump load. It would just be good in the dashboard to see the numbers and figures and a comparison of different strategies, to validate that what I have is more efficient.
I will not be using it unless an option is added
What automations are you seeing? I don’t see anything new like that in my app? Or is it only on the web dashboard?
On the web dashboard there is a new widget.
Ah I see. Yeah, based on the description in the disclaimer I wouldn’t enable that (because I don’t want to lose all control over battery schedules).
But the legacy version is being deprecated in August, so it seems like there won’t be a dashboard widget that simply shows your tariff info without also taking control of your battery? There’s definitely a need for both.
