Phone upgrade and no local network on app
I have upgraded my phone from iPhone 8 to iPhone 16 everything transfers over ok but now the app does not connect on home setting says local network failed all the time.
How do I go about rectifying this issue.
Thanks Derek
Go into the settings then local monitoring in the app, set the IP address manually (assuming it is static/permanently reserved on your router).
Also might need to allow location services for the app if you haven’t already. If I recall correctly.
Thanks for that the local network was turned off in settings in the settings for app on phone.
Turned it back on and them manually searched for the inverter in the givenergy app and added it.
Seems to be working just now.
Derek
