Question about scheduled discharge
Does the scheduled calibration take the battery down to the reserve value (which I have set to 10%) or does it override this for the calibration and take it down to the cutoff of 4%?
Hi yah, good question, a calibration is designed to work out the very bottom and top of a charge to determine the correct SoC, so would do this irrelevant of what settings you have, once finished it will then abide by your settings.
Correct @daveb01 and to expand, the calibration will discharge as far as it can do, often below what is marked as 4%, and find out what the new 4% figure should be based on the current battery range it finds from the empty to full discharge/charge
