Real life round trip efficiencies
Hi All,
I see lots of brochure materials stating 93% round trip efficiency for the All In One, and then talk on the forums of real life 80% round trip efficiency for gen1/2 inverters - and I guess the boxes take some power to run.
Anyone got any real-world round trip efficiency stats on the All in One please?(Assuming the firmware gets fixed). This efficiency figure is key when I look at my spreadsheet about whether the box pays back its installation cost or not - especially with power prices falling.
Thanks!
Paul
HT3.6 Gen1; 5.2 Battery; 3.6kW array
My first year of system use is almost up and these figures are based on the battery charge in [from both solar and grid] to battery charge out. I use this as round-trip efficiency and for me is 83%. There will no doubt be some variability with differing amounts of solar and grid charging, and some tolerance in the measurements; however it is 12 months worth.
There are still some software ‘features’ which I hope will be corrected shortly, causing unexpected sudden loss of charge.
I had a 13.5AIO installed in late November, looking at the GECloud page, helpfully battery charge = battery discharge
But, if I dip sample the usage charts, battery export is around 10-13% higher than the domestic load it’s covering - not very scientific unfortunately, but eyeballing the charts, looks like a fairly consistent difference between battery discharge and corresponding load.
Equally un-scientific, but once we’d moved to a tariff with 5p overnight rate where I could cheaply charge the battery, our daily electricity costs dropped from £4-£5 to <£1 as the AIO was usually enough to cover the full load all day and avoid peak rate energy consumption, often with excess that I could export at 12p.
Since we had the ASHP installed late January, I don’t have an excess to export, but most days we still manage to avoid peak rate importing.
Apologies, had stumbled on this thread and hadn’t noticed it was from Feb ‘24, not Feb this year.
