Hi James, I have exactly the same issue/question with similar figures:
⦁ 10.5kWp solar
⦁ 8kW hybrid inverter
⦁ 10.2kWh battery (charges/discharges at max 6kW)
⦁ 5kW export limit
Also like you, doing as wrighar described in his post. This works brilliantly on the really sunny days. We manage to catch almost every photon and export most of them by emptying the battery first thing and not charging it at all until we are already at exporting 5kW.
But like you, found that setting an export percentage limit does not just limit export, it limits all discharge. So the house then draws from the grid when the sun goes in.
But it’s worse than that. Even if I toggle off the timed export slots so that I can’t even see the ‘export to’ slider, the battery still refuses to cover the house load if this percentage was set higher than the current battery SoC. Having any value set on this slider seems to override the reserve set for the battery operating range.
Eco is switched on. Timed discharge is set to 05:30-23:30. I have tried toggling timed discharge on and off (with timed export off) and get the same result. I have to turn export back on, move the slider right back down, and turn export back off again to get the battery to cover the house when the sun goes in but not drain the battery into the grid in the evening.
My workaround over the summer was to leave the ‘export to’ permanently at 4% and instead adjust the grid export limit slider up and down (depending on solar expectations) so that I didn’t accidentally drain the battery leaving us short before night rate kicked in. However mistakes were made.
Another disadvantage of this workaround is that the battery is working a lot harder than it should need to on all but the sunniest of days when it unnecessarily drains to maintain the export when the sun goes in and then needs charging back up again.
This week this workaround stopped working anyway as reducing this slider has suddenly started resetting the hard max export limit of 5kW down to whatever the slider was last set at. After the second time in two days of asking the installer to reset it back to 5kW, I’m now leaving it alone.
I do use home assistant, but there are still connections issues with GivTCP. Same with my phone - it can’t access ‘home’ - it’s a bug that they supposedly fixed a week or two back and it’s better but still not reliable enough to rely on HA automations.
But I feel that I shouldn’t need to resort to home assistant for this. It should all work as required if the “export percentage limit” only applied to export and not to covering the house load too. This would also avoid excessive, unnecessary cycling of the battery on less sunny days which can’t be great long term.
