I’ve had this installed for about 18 months now but never set any charging schedule, I’ve just started now as I’ve changed tariffs and want to charge at the cheaper rate.
Charging only seems to work with the quick charge option in the app.
I have tried various things for scheduling charges:
- Manually changing the timed charge times
- Using Octopus R&D
- Using WonderWatt
- Performing the API calls manually
And, yes, timed charge is set to ‘enabled’ ![]()
I can see in the Inverter logs that the calls to the inverter are being received and logged but it just doesn’t seem to charge at all.
Here are my inverter details:
Inverter Model - GIV-AC3.0
Software Version - D0.205-A0.205
Battery Type - Lithium-ion
Battery Capacity - 186 Ah | 9.52 kWh | (1 Pack)
Last Software Update - 2024-10-11 10:45:26
Last Online Time - 2024-11-24 14:56:42
Warranty Expiry Date - 2033-04-11
Commission Date - 2023-04-11
Thanks, Daniel.
