Weird values shown in GiveEnergy app
Hi, hoping someone can help.
Yesterday I noticed some really weird values shown in the energy graph section on the giveenergy app. I was expecting around 2-3kw usage over the day, due to it sunny and the home usage primarily from solar or the battery. I have 3 extremely large spikes on the grid import view of 10kw each. This is clearly wrong and not even possible. The export view is also showing values which don’t seem correct. I was expecting around 20kw to be exported, which it is, but it seems to showing battery export when it should be showing as solar export.
In the power graph view, it all looks about right and the same when I look at the dashboard on the online giveenergy cloud login. The legacy view of the energy graph on the cloud view also shows the correct values. Do I just leave it or would it worth contacting giveenergy?
Very bizarre, while browsing when logged into the cloud app, the figures have now changed and now showing the wrong values!!
There are other apps and software that can give you alternative figures (reluctant to say correct where GE is concerned!). If you have an android device try
By default all you get is an instant snapshot; to get minute-by-minute, daily, and monthly history, turn on “Collect Stats” in settings. Once you have collected at least a days data, it is possible to transfer raw data from the portal and get better figures.
unfortunately don’t have an android device. I did end up contacting them via the live chat for giveenergy and was advised its affecting a lot of end users and they hope to have it fixed by the end of the month!!
Same problem here. 2 Android devices
Uninstalled app.
Reinstalled app = back to normal
Did it fix the incorrect values from previous days?
I just tried that. Unfortunately made no difference. Apparently I exported 34kWh from my 9kWh battery yesterday.
It did not correct the errors but erased the wrong entries leaving blanks in the record.
This was enough for me as I just wanted to know l could rely on future readings for day to day management.
Cross checking with the octopus app was enough to reassure me I wasn’t getting stung for huge downloads from the grid
Same issue here since the 9th. GivEnergy just said they were “working on it”.
Got same issue. My app data is all over the shop.
Actually generated 30kwh today however give app says 52kwh.
Give web portal says 28.8kwh. With losses etc that’s about right.
I did see an known issues update on my web portal this evening regarding this. Apparently a fix has been made.
To make matters worse. Now my battery is stuck on 100% and not discharging. Have restarted the battery, but still the same issue.
Not very impressed with a system that’s only around 6 months old
I had this issue, turned out that an mcb on the left side of the battery had tripped.
Hope this helps
