Wi-Fi connection to AIO
Hi, we have Solar, AIO 13.5Kw batt & Gateway plus Growatt inverter.
This was installed in September a week before we went abroad until last week. The whole time we were away we could monitor the system with the app on the Away section. Now we are back we have had no end of trouble maintaining a wi-Fi connection either on the Away or Home section of the app.
The AIO is in the garage and we installed an extender there (before going away) so there is a good Wi-Fi signal there. I have restarted the system many times, and occasionally this sorts the problem but it keeps loosing the connection. Sometimes it reconnects spontaneously.
I am not particularly tecchi so will not understand a load of jargon, but hopefully someone can advise me on how to cure the problem.
Just joined the forum and I realise that this issue has been aired previously and apologise for bringing it up again, but can’t see a solution there.
Did you get this sorted?
Have you tried doing the firmware update on your AIO - it’s honestly far easier than it might seem in the guide Tech Support send with the file ?
I had issues during first 24hrs with WiFi dropping, but has been solid since I updated firmware.
