For several years I have been using a Raspberry Pi to provide the wifi connection for the WiFi dongle.
However, on the time change on 30th March this failed and would not reconnect. So I worked out how to connect it to my network repeater. I have discovered that the WiFi dongle doen’t like to negotiate. So I have set up a separate connection on the network repeater for 2.4GHz and I set the WPA security mode to WPA2(Comp).
I found that if the WiFi dongle is offered 5GHz or 2.4GHz it fails to connect and if it is offered WPA2 + WPA3 then it also fails to connect. With these configurations then it might connect then fail a short time later. With 2.4GHz and WPA2(Comp) it stays connected.
My router already can connect to WPA3, fortunately with the repeater I can separate out the connections to 2.4GHZ and 5GHZ so I can connect to 2.4GHZ only and I can set it to WPA2. I use a Fritz!Box 7490 as my router with a Fritz!Repeater 1200.
