You seen this new WINTER setting?
Just checking the webpage and saw this !!!
Nice of them to give use the choice to opt out - rather that opt in !
Thanks for the heads up, I didn’t see that.
Be careful with this setting though if you are using force charge slots to charge batteries using off peak rates.
The winter setting seems to detect when the batteries are getting cold, then sticks a 10 minute period into Force Charge timeslot 1 and sets Force Charging to ON.
OK so far…
The problem is at then end of the 10 minute period Force Charging is set to off again and so if you have charge periods set in any of the other slots they are not going to kick in and you won’t charge.
So using Winter Battery Conditioning and scheduled force charging seem to be mutually exclusive.
Otherwise its a nice idea.
(I have got around the problem by implementing something similar but using Home Assistant where you can control things properly)
