Charging speed has changed since 1st January
since 2nd January this year, the battery charges at 2.7KW. prior to that, it charged at 3.4KW.
i’ve checked settings which all say its set at 3600w. I haven’t played with it!
Any suggestions where to look for the gremlin setting to get it back to faster charging?
I suspect it’s because it’s been cold… it throttles the charge rate
Battery software 3017 and 3018 limit the charge rate to 60% if the average temperature of the battery (as measured by the 4 sensors) is below 21 deg. Note this is not the BMS temperature which is on a circuit board and is usually hotter. To see the 4 sensor temperatures use the App “Monitor for GivEnergy Inverter” by Andrew Miller.
I’m assuming this is also why I’m occasionally getting 1.9kw charge instead of 4.87ish from my 5.2kw gen 1 battery. The winter battery conditioning doesn’t seem to take effect because my battery is loft mounted and reads over 10c, but on British gas Peaksave days (Sunday 11am-4pm at present), if I charge from the mains after having little/no charge in the dreary weather during the week, it says 100% charged after an hour, but only contains 1.9kw. The solution I found weekend just passed, was to turn the charge from grid off after an hour, let it run down, then charge it again - not ideal :(
