EV Charger got removed from App and QR Sticker faded no longer available to setup with WIfi
Continuing the discussion from Setup EV charger without QR sticker?:
Could you please help. The Givenergy App no longer shows the EV charger and has to setup again. The problem is the QR code on the unit is faded and no longer available. The outer serial no is CI2352G066. How do i setup again can you please send the instructions? My EVSE number is 53531794. The wifi SSID EVSE-53531794 also asks for a password which I don’t know.
Your response will be much appreciated. Thanks
Hi there. I had this problem and theres a helpful guy on here who can give you the serial number to put in, once he has the wifi network your charger broadcasts.
He also said:
“ an easy way to add is using the web GUI found at 192.168.4.1
login 12345678 the EVC has been reset. if it was previously done by app, then there is no way on, other than using app”
I didn’t try this but it might help you, I imagine youd need to hardwire a laptop into the ethernet port and point a browser at that address.
Sent to your support ticket request
The Charger is now online and setup correctly with the details you have shared. Many thanks for your assistance.
Much appreciated.
Any chance you could help me with qr code/ access codes to use setting up my Givenergy EV Charger please?
The existing qr code is faded and unreadable
It broadcasts
EVSE-06838847
Serial no:- C12405G118 and
87023906838847
Many thanks
JG
