GivEnergy Gateway
Can anyone help me?
I got a 3kw inverter and 3 battery’s , i would like to put a Gateway on it so if there a power cut the solar panel will still work.
Can anyone tell me if i can be done and the cost I’m from Plymouth.
Andrew
The gateway is used with AIOs only. You could use the EPS output from your inverter. You may need to get it enabled on the inverter and it will be limited to the output of your battery. See this thread for details EPS Wiring Query
