Want to update firmware manually...how do I confirm generation/model type?
Hi all
Am assisting a friend with his Givenergy setup. He was having problems with it dropping off the Wifi network so have run an ethernet cable instead. Dip switch configured and is happily receiving its ethernet IP address from the router via DHCP (have disabled the DHCP on the Inverter interface). It pings fine internally but still has issues communicating and won’t perform a firmware update the ‘easy’ way via the web browser or app. So will have a go using the USB method.
Model number is: GIV-AIO-AC-13.5
Serial numbers visible: WJ2315G072 , V56B5 , CH2315G072
Have found firmware files at:
Method here:
https://solar-tech-support.co.uk/brands/givenergy/setup/firmware-update/
Maybe I’m missing the obvious(!) but does anyone know what generation this unit as I can’t seem to find an obvious reference to it in the firmware files.
Regards
Adam
It’s a Gen2 all in one.
The 11-character GivEnergy serial number format is a strict alphanumeric code split into five distinct data sectors. It functions as a complete hardware blueprint for the unit.
The complete structural map of every variant option available within each segment of the code breaks down as follows:
[CH]  [23]  [15]  [G]  [072]
Model  Year  Week Gen  Sequence
  1. Model / Hardware Family Identifier (Characters 1–2)
These two letters designate the exact model category or component type within the home energy ecosystem. [1]
  • CH: All-In-One (AIO) Gateway or Inverter Unit. This indicates a premium system combining high-capacity inverter architecture with a specific GivEnergy Gateway.[1]
  • SA: Hybrid Inverters. Used for standalone, wall-mounted multi-string hybrid hardware paired with separate modular battery banks. [1]
  • CE: AC-Coupled Inverters. Used for battery-storage-only retrofit configurations where a pre-existing solar PV system is already installed on an older, independent inverter.
  • SD: Single-Phase String Inverters. Used for standalone solar PV conversion systems containing zero battery integration.
  • BG / BP: Battery Packs (GivBat). Found exclusively on the exterior labels of independent modular battery enclosures. [1]
  • WH: Data Communication / Wi-Fi Dongles. Identifies the plug-in network communication stick providing portal sync capabilities. [1, 2]
  1. Year of Manufacture (Characters 3–4)
A two-digit fiscal manufacturing year marker. [1]
  • 21: Manufactured in 2021 (Early hybrid and modular models).
  • 22: Manufactured in 2022 (Introduction of the earliest AIO prototype frames).
  • 23: Manufactured in 2023 (Your unit’s year).
  • 24: Manufactured in 2024 (Peak production era of Gen 2 models).
  • 25 / 26: Manufactured in 2025 or early 2026. [1, 2, 3]
  1. Week of Production (Characters 5–6)
A two-digit calendar week calculation tracking when the unit rolled off the assembly assembly lines.
  • 01 to 52: Represents weeks running from the first week of January through late December.
  • Your designation (15) points precisely to the middle week of April.
  1. Hardware Generation Code (Character 7)
This letter marks major design overhauls, internal mainboard changes, and technical revisions.
  • A or E: Generation 1 (Gen 1). Found on legacy modular hybrids and first-generation infrastructure. These rely strictly on older exterior pocket-dongles for cloud synchronization.
  • G: Generation 2 (Gen 2). (Your unit’s generation). Denotes advanced system safety parameters, updated internal relay groupings, and unified architecture designed for grid islanding capabilities.
  • H or K: Generation 3 (Gen 3). The modern product group featuring fully integrated, native Wi-Fi/LAN ports directly baked onto the internal mainboard, removing the need for an external physical pocket dongle entirely. [1, 2]
  1. Production Tracking Sequence (Characters 8–11)
A final three-to-four digit sequence.
  • 001 to 999: Sequential production unit numbers assigned consecutively on the factory floor during that specific production week.
Thank you Willy. That information is very helpful to many of us on this forum.
Thank you WillyReckitt
Really good information there.
I’m going to hold back from the firmware at the moment as further study reveals there is no redundancy should the update fail! As you username suggests, there’s a chance I could easily brick the unit!.
Going to try a couple more bits and pieces before even pondering that again. Namely ensuring that the hostnames for the inverter and gateway aren’t the same. You can do this in the dongle interface apparently.
Cheers.
